Product Options - Metal/Color and Size
Thread begun 9/19/2011 11:39 am by Patbyrne322425963 | Last modified 11/01/2011 6:50 am by Jason Byrnes | 9326 views | 31 replies |
Patbyrne322425963
Alright, so I am creating a wholesale jewelry site and would like to have 2 options - size (different prices by size) and metal (gold/silver, with price difference).
The thing is, not all jewelry items are available in both gold and silver and not all items have a size option (only rings). Also, not every ring is available in every size.
So the way I set it up was I added a column in my products table for ProductCategory, which contains the first few numbers of the SKU.
I would like the product options to show size options for rings (ProductCategory=400) and metal options for ProductCategory=635. I have my tables set up like this:
optiongroups:
OptionGroupID | OptionGroupName
1 | Size
2 | Metal
options:
OptionID | OptionGroupID | OptionName
1 | 2 | Sterling Silver
2 | 2 | 14K Gold
3 | 1 | size 3
4 | 1 | size 4
5 | 1 | size 5
productoptions:
ProductOptionID | ProductCategory | ProductID | OptionID | OptionGroupID | OptionPriceIncrement
1 | 635 | - | 1 | 2 | -
2 | 635 | - | 2 | 2 | 2.00
3 | 400 | 400101 | 3 | 1 | -
4 | 400 | 400101 | 4 | 1 | 0.50
5 | 400 | 400101 | 5 | 1 | 1.00
products:
ProductCategory | ProductID (primary key) | ...Price, Desc, etc
635 | 635101 | ...
635 | 635102 | ...
400 | 400101 | ...
400 | 400102 | ...
Now, starting with metal (because I gave up on size to focus on this part), I have this in the SQL for rsMetal:
SELECT productoptions.OptionPriceincrement, productoptions.ProductOptionID, options.OptionName, options.OptionGroupID, optiongroups.OptionGroupName
FROM options INNER JOIN productoptions ON options.OptionID = productoptions.OptionID INNER JOIN optiongroups ON options.OptionGroupID = optiongroups.OptionGroupID
WHERE optiongroups.OptionGroupName = 'Metal' AND productoptions.ProductCategory = paramItem
With ParamItem default value: -1, runtime value: $row_WADAproducts['ProductCategory']
I'm following the rest of the directions exactly from the Product Options how-to for the dynamic menu and all I'm getting is a blank menu with the heading "Choose a metal." I don't know what I'm doing wrong.
when dealing with options, you should only have the Add to cart button on the Product Details page.
To load the product detail page, the product ID will be passed as a querystring variable.
the option recordset should filter the productoptions.ProductID column on the passed Querystring, for example if the querysting is named productID:
productsDetail.php?productID=12
the where clause should be:
WHERE optiongroups.OptionGroupName = 'Metal' AND productoptions.ProductID = paramItem
and the run time value for the parameter will be:
$_GET['productID']
Patbyrne322425963
I've only got the add to cart button on my product details page. I have it linked from another page as productdetails.php?ProductID=<?php echo $row_products['ProductID']; ?>
On productdetails.php on the products recordset, I have the clause: WHERE ProductID = colname
and runtime value for colname: $_GET['ProductID']
Do I need to create a second copy of the item page for items that have product options and include those clauses instead?
Patbyrne322425963
Wait, that's what I have now, only I have it under rsMetal (as posted above). So I changed the runtime value for the paramItem to match what you posted and I got the same result. Do I have those clauses on the wrong recordset?
you need to create the recordset to look up the options on the product detail page as:
then create the parameter paramItem using the run time variable:
$_GET['ProductID']
Patbyrne322425963
Still nothing in the drop down menu.
send a copy of the page in a zip archive please and a link where i can see this in the browser.
Patbyrne322425963
itempage.php?ProductID=635001
in the rsMetal recordset, you are suing the productoptions.ProductCategory column in the where clause:
you need to use the productID column:
Patbyrne322425963
Thing is, on the 635 group, I want everything with the ProductCategory 635 to have the metal option. I have hundreds of products with that product category and don't want to enter them all again separately in a second table. With sizes, because every item isn't available in every size, I understand that I will have to do them individually. The reason I created the ProductCategory column was so I could apply the metal option to an entire grouping of products at once.
edit: Note that the 635 ProductCategory doesn't have a number in the ProductID column (first post).
