URL rewrite extention
Thread begun 9/19/2011 3:12 am by mrs | Last modified 9/20/2011 12:48 am by Dave Buchholz | 1368 views | 1 replies |
mrs
Hi, is it possible to create a URL rewrite extention so we can achieve better SEO?
I understand that currently, the readability of the URL is quite important. So basically this URL:
forumdisplay.php?f=8
could look like this:
extension-wishlist/
I've tried to understand this, but I just can't get to grips with doing it manually :o(
Dave BuchholzBeta Tester
This isn't something that can be accomplished using an extension as it requires a "holistic" approach. You need to set up your database/code to carry the url values to want to pass.
This tutorial should get you going and then this one is more applicable to how you would want to do things using WA tools.
