notifying a bug or not sure if intended
Thread begun 9/18/2011 8:30 pm by Miguel | Last modified 9/19/2011 1:08 am by Dave Buchholz | 1444 views | 1 replies |
Miguel
Hello i think it can be a bug with css form builder, the point is that if i use the simbol " | " it cuts the texts and adds them to the other form fields when i click the submit buttom , example if i have a form with 3 text fields 1 text area and 1 html editor area if i place on any field a text like this on one field
text abc | second text | other text | text 123
this text when i submit the form will be saved wrong, each bunch before | will insert on the next field and so on.
Please look at the image attachment so you can see what i mean
Now my question is is there any way to avoid this before when i used addt i could place text with those simbols without any problems now to make a simple thing every things gets added wrong...:eek:
Dave BuchholzBeta Tester
This has been brought up before on the Data Assist forum, see this thread http://www.webassist.com/forums/showthread.php?t=22423 for a possible solution
