Problem with dreamweaver after installing Security Assist
Thread begun 9/17/2011 10:16 pm by arturo.civit | Last modified 9/19/2011 9:50 am by arturo.civit | 2780 views | 4 replies |
arturo.civit
Hi there, after installing Security Assist my DW started to act weirldy, when I start DW I start to receive 4 warnings, all of them attached, can someone take a look and let me know, whats wrong? I'm starting a gig on Monday when I need this extension, purchased for this project and now my DW is not working. Also I'm attaching a screenshot of my extensions just in case.
Thanks a lot!
Arturo
arturo.civit
Just a note, I deleted the MacFileCache.dat file but it doesn't help, still the same error, also, when I try to open a document, I got the attached image, that things appeared like 5 or 6 times, please, someone from staff can let me know what to do? Thanks so much!!
Arturo
arturo.civit
Well, I just removed all the extensions and re-created the DW configuration folder and now DW runs ok, what should I do now, re-install everything again and check if works? a word from staff comes handy....
A.-
The screen shot of the Extensions manager is not readable, I cant make out what extensions where installed.
Usually when you start getting errors about translators not being loaded, it means that the configuration folder has become corrupted. This usually happens as a result of installing a newer version of an extension without first uninstalling the previous version. renaming the configuration folder then reinstalling extensions is the best way to corrrect the problem.
With Security Assist 2, make sure it is the last extension installed since it is the newest.
arturo.civit
Thanks Jason, working now!
