javascript file not loading
Thread began 9/16/2011 3:14 pm by enquiries257012 | Last modified 9/20/2011 6:51 am by Jason Byrnes | 1282 views | 3 replies |
enquiries257012
WinXP 32 bit SP3 DW5.5
Purchased Site Sculptor the other day.
When I go to build site/new site i briefly see the webassist splash screen which confirms my serial number is OK then I get a blank box. After maybe 30 seconds I get a warning that a javascript file has ben running for a long time. Do I want to continue or not. I choose yes but I get the same warning. I tried to continue three times on the run.
If I choose no I get another warning that the script file has stoped at line 40 - the user chose to stop the script
this error will occur if there is no testing server defined in your Dreamweaver Site Definition.
Double check your Site Definition settings, and make sure a testing server is defined.
enquiries257012
So without a testing server I've wasted my money ?
The sales page doesn't mention that a testing server is required. In fact the "system requirenments" say that site sculptor works fine with static sites. Why would I need a testing server for a static site ?
Dreamweaver needs to have a testing server defined.
even a static site will need to be uploaded to a webserver at some point to function as a web site. The testing server defined in Dreamweaver does not need to be a local server. If all you are using is the remote server, set it to be both the testing server and the remote server in Dreamweaver's site definition.
