want info bubble to show on load
Thread begun 9/16/2011 9:23 am by JBWebWorks | Last modified 9/19/2011 12:00 pm by JBWebWorks | 1644 views | 2 replies |
JBWebWorks
contactus.php
Map has 2 locations and i want the info bubble for both locations to show on load.
From searching the forum i found
showpost.php?p=105263&postcount=4
but when i change
var fromAddress = {
enabled: false,
to
var fromAddress = {
enabled: true,
the map goes away and the background is solid gray and only shows one pushpin.
only one info ballon can be open at a time, you wont be able to have them both open.
to have one open, find the three isntances of the following code:
if('address_1' == 'address_0')
marker_1.openInfoWindowHtml(address_1.infowindowtext);
and change it to:
//if('address_1' == 'address_0')
JBWebWorks
Thanks Jason.
