eCart Error in CS5
Thread begun 9/15/2011 11:51 am by movygirl244169 | Last modified 11/03/2011 11:29 am by Jason Byrnes | 5851 views | 10 replies |
movygirl244169
eCart Error in CS5
I keep getting error when I use the Display Manager in eCart using my CS5. It's say's there is a error on line 621. It say's "While executing timer in WA eCart DisplayMgr.htm and then a lot of other stuff and it ends with "this.color has no properties. I've tried starting a blank page and it still happens I've reinstalled eCart.
I don't know what to do!!!!!!!
movygirl244169
Here is the screen picture of the error. I didn't know how to do this until just a min ago.
goat200487425014
Im getting an error too.....
goat200487425014
Actually getting two. This one I'm getting when I click on Display Manager and it doesn't display anything. The post above error I get when I close Display Manager.
in the WA_eCart folder, there should be a file name WA_DMCFG.xml. Try renaming that file to WA_DMCFG_old.xml and try running the display manager again.
also, Delete the Dreamweaver Cache file from the users configuration folder:
goat200487425014
Still not working...
goat200487425014
Updated....
goat200487425014
What time are you available to work on this???
