FB writing errors and producing blank page
Thread begun 9/15/2011 11:45 am by MBrem | Last modified 9/16/2011 7:16 am by Jason Byrnes | 2136 views | 3 replies |
MBrem
Hi, When I insert a form with FB 2.0, everything happens as expected. However, upon completion, DW tells me that there is syntax errors which it then flags in the code. When I attempt to preview the page, the browsers show a blank page.
File attached.
Use the Form Builder 2.0.1 Support Release 2 version that is available for download on the download center page, you will need to uninstall the previous version before installing the newer one.
MBrem
Thanks worked like a charm.
The version number on the download area does not reflect the true version number of the extension. So, I didn't look within the product area for a incremental update since the download landing area is pretty specific: 2.0.0. Maybe you can pass that along unless you like the job security that comes from answering questions like mine!
OK, I will pass that along.
