Formatting changes
Thread begun 9/14/2011 6:05 pm by Paul | Last modified 9/15/2011 10:06 am by Paul | 3816 views | 6 replies |
Paul
Formatting changes
Every time we go into the iRite editor to change some content, it changes the formatting from what was originally created to a default.
Edit:
I upgraded from iRite to HTML Editor 3.02 hoping to fix the error mentioned above. Now, when I go into a page to edit the content and hit UPDATE, it wipes it out. The page is blank.
Any ideas?
I dont quite follow what you mean by this, can you send screen shots to illustrate the problem.
A blank screen means that a php error is occurring, add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
Paul
What I meant is, if I have a page that is just text and I format it with bolds and colors and save it from within iRite, the live page looks fine. If I then go back into the iRite Update page, the formatting is all gone although the content is there.
So what I did was I bought and updated the admin page with HTML Editor 302. Re-uploaded the page and the Webassist folder (I did follow the instructions about removing the iRite extension first). When I went to the results page the content is there but as soon as I went into the Update page, the content disappeared from there as well as the live page.
I put the code you gave on the Results page and here is the error:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/moret608/public_html/admin/AboutUs_Results.php:5) in /home/moret608/public_html/WADbSearch/HelperPHP.php on line 11
I wasn't sure if you wanted it on the UPDATE page as well, so I put it there but it returned nothing.
EDIT:
Jason, I remade the pages and they are working. I was implementing it incorrectly. Once the update page was made, I selected the record and then inserted the Editor and it picked up all the information properly.
The problem still exists with the formatting changes. If I make visual changes to the page, bolds, colors etc., it saves it fine the first time. But if I go back in to edit the same page again, all the visual formatting I made is gone and the text is just black with a default font.
Thoughts about that?
send a copy of your page in a zip archive so I can see the code please.
Paul
Here is the update page
There is formatting code on the initial value of the HTMLEditor instance that is converting double quotes (") to the html entity "& quote;"
edit the html editor instance, click the lightning bolt next to initial value and reselect the Description column from the recordset, this will remove the formatting code.
Paul
That fixed it Jason. Thanks again!
Paul
