Website Background applied to CKEditor
Thread begun 9/13/2011 9:52 pm by info401175 | Last modified 10/21/2011 4:41 am by kertjoert431519 | 2697 views | 2 replies |
info401175
I have an background image set on the body tag in the css of my website.
This image is also appearing in the CKEditor window when i type any text into the cms.
Is there any css i can change so the body background doesn't show in the CKEditor window.
Configurable.css
body {
background: #000 no-repeat top;
font: 11px Arial, Helvetica, sans-serif;
color: #555;
margin: 0;
padding: 0;
html, body {
height: 100%;
background-image: url(../../../../imagesadmin/backgrounds/background.png);
create a copy of the configurable.css file as configurableHTMLEditor.css
In the configurableHTMLEditor.css file, remove the background image from the body
on each of the pages that has the HTML Editor instance, find the following code:
$CKEditor_config["contentsCss"] = array("../webassist/themes/". ($WAGLOBAL_Page_Theme)  ."/css/configurable.css");
and change it to point to the configurableHTMLEditor.css file instead:
$CKEditor_config["contentsCss"] = array("../webassist/themes/". ($WAGLOBAL_Page_Theme)  ."/css/configurableHTMLEditor.css");
kertjoert431519
Hey..,
I got it you are right Jason Byrnes..,
I too experienced with the same problem...
Thanks for the hint with the missing line of code, I will try it right away.
premium wordpress themes, wordpress themes
