URL Error
Thread began 9/12/2011 1:43 pm by brian.e.bond429783 | Last modified 9/13/2011 10:19 am by Jason Byrnes | 2793 views | 10 replies |
brian.e.bond429783
URL Error
Jason,
First off I wanted to thank you for all of your help on the phone last week. after we finished, I made some changes to the database naming convention as you suggested. After that, I re-ran the Data Assist Wizard. I am now getting the following error message after I insert data and click "Insert". The requested URL "/Applications/MAMP/htdocs/NOS/tblAccountInfo_Detail.php was not found on this server".
The form is submitting data to the database, but it appears something is still not provisioned correctly. Any ideas? I can send you screenshots if you don't remember how it's configured. I'm using a MAC with MAMP and the default settings. Thanks
Brian
there is a fix for this issue in the known issues section of the data assist download center page.
brian.e.bond429783
Do you have the correct path for MAC OS Lion and Dreamweaver 5.5? It appears to be different.
brian.e.bond429783
correct path to what? the configuration folder?
it should still be the same, though it looks like the library folder is now a hidden folder:
cpsid_90508.html
cpsid_90947.html
brian.e.bond429783
ok, so I was able to locate the library folder and replace the library.php file. I then closed dreamweaver and relaunched, but got the same error message after click "Insert" on the form. Do I need to re-run data assist wizard? My current library file is dated 12/22/10.
can you send a copy of the insert page please.
brian.e.bond429783
Here ya go... thx again.
tblAccountInfo_Insert.php.zip
try commenting line 11, change:
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
//if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
brian.e.bond429783
Bingo... that worked... thank you... can you explain why that happened? Should I have done something different, or will I have to remark this line out all of the time?
