Shipping based on Total Weight in cart
Thread begun 9/12/2011 1:41 am by martin400112 | Last modified 9/12/2011 7:48 am by Jason Byrnes | 1432 views | 1 replies |
martin400112
I have a client who requires custom shipping rates and I am having trouble nailing it in the ecart object. This is what she requires:
1: £x for total weight less than 1000g
2: £x for total weight more than 1001g but less then 1999g
3: £x for total weight more than 2000g
I can't figure it out and any help would be greatly appreciated.
Many thanks,
Martin
you will need to create a separate shipping rule for each weight range using the Subtotal For Any Column.
for example:
Name: total weight more than 1001g but less then 1999g
Triggers:
"Subtotal For Any Column"
If the Subtotal of column "totalWeight" is ">=" a value of "1001"
AND "Subtotal For Any Column"
If the Subtotal of column "totalWeight" is "<=" a value of "1999"
Calculation:
Flat rate charge of "x"
