error file
Thread begun 9/11/2011 3:47 am by QuiruNet | Last modified 9/13/2011 6:53 am by Jason Byrnes | 2863 views | 5 replies |
QuiruNet
error file
i get this error:
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 7020 bytes) in C:\Inetpub\vhosts\cemasce.es\subdomains\tienda\httpdocs\WA_DigitalFilePro\HelperPHP.php on line 844
how i can fix it. I send you the file..
add the following code at line 1 of your php page:
ini_set
("memory_limit""256M")
QuiruNet
i get that one now...
Fatal error: Maximum execution time of 30 seconds exceeded in C:\Inetpub\vhosts\cemasce.es\subdomains\tienda\httpdocs\WA_DigitalFilePro\HelperPHP.php on line 890.
I some page using the same extension, in other pages it let me insert 1 m o 2 m files, now i am traing to upload 418 kb.....
try adding this code at line 1:
set_time_limit
(0);
there are a number of PHP.ini settings that may need to be adjusted depending on the size of the files you are uploading.
see the following page for details on settings that effect file upload size:
wap_upload.asp?page=php2
QuiruNet
chage
This post has been deleted.
QuiruNet
i put that way:
ini_set("memory_limit", "256M");
set_time_limit(0);
i that gime the next error {insert record data assit header location, i send you the file}:
Warning: Cannot modify header information - headers already sent by (output started at C:\Inetpub\vhosts\cemasce.es\subdomains\tienda\httpdocs\admin\productos_insertar.php:5) in C:\Inetpub\vhosts\cemasce.es\subdomains\tienda\httpdocs\admin\productos_insertar.php on line 174
you have a blank space at the end of line 4 that is causing this error:
see the following thread for more details on troubleshooting the headers already sent error:
showthread.php?t=19285
