How Limited is Security Assist 2.02
Thread begun 9/06/2011 2:16 am by ovknox388992 | Last modified 9/06/2011 11:32 am by Jason Byrnes | 1430 views | 1 replies |
ovknox388992
I am working on a project where I need to capture different kinds of information from clients on multiple registration forms. One size will not fit all in this situation. Will I run into problems if I create multiple sets of login & registration pages as long as I keep each set in a different table? If I do this will I run into problems managing access to pages? If this is not practical I would appreciate knowing now before I spend any more time with security assist. Thanks
you should not run into an issue with this as long as each set of pages is created with a unique name and uses a unique table. also each table will need to use unique column names to prevent the session for one login from over writing the session for another login
