tImageDIM has no properties
Thread begun 9/05/2011 10:45 am by evansg7124312885 | Last modified 3/07/2012 1:44 pm by Jason Byrnes | 3518 views | 6 replies |
evansg7124312885
CSS Forms opens with no issues other than hitting for serial number every time DW has been started, but will hit you with error as soon as you change a drop box setting, all appear to do the same thing on change. There is also no preview available, and I would guess no form if I was to run it all the way through.
Error message reads:
Error generating form:
Type Error: tImageDIM has no properties
error will flash 3 times on selecting form type in step 1.
You may find a prior incident with Paul K and me that we ended up with a work around to get any DW extension to work. I do not know if related or not; WA has not been used much on this system since.
CSS Forms 2, MAC OS 10.6, DW CS4.
No HTML editor or other extensions (HTML Edit, Digital FIle, Validations toolkit) installed.
Try using the CSS Form builder 2.0.1 Support Release 2 version that is available for download from the Form builder download center page.
You will need to uninstall CSS Form Builder 2.0.0 from the extension manager before installing the 2.0.1 Support Release 2 version.
evansg7124312885
Just ran recommended fix, no change in problem. Please advise.
evansg7124312885
Matching problems between Sec Assist 2.02 and CSS Forms 2
Attempted to run Security Assist 2.02, got the same problem as what original thread was posted for. I see Security Assist 2.01 had a fixed that looked like it was similar; any chance this is related?
I do not know if seen or not, but Jason recommended removal of CSS Forms and replacing with newer version. Tried this, no change in problem; both extensions are currently inoperative, please advise.
evansg7124312885
Issue is still present
I have not used in a while, but needed to this morning. We never did resolve as I went to work on a Windows machine for a while. I went to use it this morning and the same problem is present. Can we reopen support ticket?
