WAValidatePN problem
Thread begun 9/04/2011 1:34 pm by davidrmilne363485 | Last modified 9/06/2011 7:53 pm by davidrmilne363485 | 1952 views | 2 replies |
davidrmilne363485
I am having problem with a phone number field. When I enter 555-555-1212 it reformats it to (555) 555-1212 and then tells me that I have exceeded the maximum number of characters.
Go to registration.php to duplicate the error. This page was built with CSS Form Builder 2.0.
Here are two code snippets that show the calls to WAValidatePN
$WAFV_Errors .= WAValidatePN((isset($_POST["Phone_Number"])?$_POST["Phone_Number"]:"") . "",false,true,true,4);
and
<input id="Phone_Number" name="Phone_Number" type="text" value="" class="formTextfield_Large" size="15" tabindex="4" onblur="WAValidatePN(document.getElementById('RichRegistration_NewFromBlank_Default').Phone_Number,'',false,true,'x (xxx) xxx-xxxx',document.getElementById('RichRegistration_NewFromBlank_Default').Phone_Number,0,true);"/>
<span class="textfieldInvalidFormatMsg">Invalid format.</span><span class="textfieldMaxCharsMsg">Exceeded maximum number of characters.</span><span class="textfieldRequiredMsg">Please enter a 10 digit phone number</span> </span>
Thanks for your help.
Regards,
David
the spry validation code for the phone number field is set to restrict the maximum characters for the phone number field to 14:
var Phone_Number_Spry = new Spry.Widget.ValidationTextField("Phone_Number_Spry", "phone_number", { format:'phone_us', maxChars:14 , validateOn:["blur"]});
the format:
x (xxx) xxx-xxxx
is 16 character long though, to use that format, you will need to change the spry validation to allow for 16 characters.
davidrmilne363485
Thank you
Changing the spry variable fixed the problem.
