Getting Runtime Error R6025
Thread begun 9/02/2011 3:23 am by jeff382039 | Last modified 9/27/2011 6:47 am by Jason Byrnes | 2387 views | 3 replies |
jeff382039
Runtime Error!
Program: C...
R6025
-pure virtual function call.
In datassist. I did everything that was suggested in all the ongoing reports of this. I did get it to work once after reinstalling, however it duplicated all the code on the results page.
I see that this problem has been occuring for two years now, but now there is a lot more of it as of late. This error started appearing for me after installing security assist 2.0 and occurs in all my extensions.
I tried reverting back to security assist 1.0 but started getting tons of errors about missing floats ect, so had to go back to 2.0.
Now none of my extensions work. I have the Super Suite. Reinstalling, deleting configuration folders and that darn wincache file do not work.
Windows 7 Ultimate, CS4
Jared Lui
Has there been any progress on a finding out why this happens and how to permanently fix this issue?
This work around is not a solution as it seems to revert back to it's evil ways the next time I want to use DA. It's a long and frustrating process and I'm wondering because if you can't fix it in DA2 then I can only assume this issue will be in DA3 as well.
Users who ran into this issue in the past got it working by Deleting the Configuration folder and reinstalling the extension.
To do that, please browse to your Dreamweaver Configuration folder (You can find your configuration folder by looking in the following pdf common_installation_issues.pdf) and rename the configuration folder to Configuration_old.
Open the extension manger and remove all extensions and then install only DataAssist. Open Dreamweaver and try it again. If you still get the error please let me know.
