Configuring IIS on XP for dynamic development
Thread begun 9/01/2011 5:23 pm by galen.m402136 | Last modified 9/02/2011 9:32 am by Jason Byrnes | 3405 views | 3 replies |
galen.m402136
Hello. I am running a functioning IIS on Windows XP Professional. I have downloaded PHP version 5.2.17. Your tutorial instructions ("Web Development: Before You Begin, Preparing your system for dynamic development") for configuring IIS on XP tells us to input an executable file name (php-cgi.exe) into IIS manager. The file does not exist in PHP version 5.2.17.
I am therefore unable to run a php server on m machine. Any ideas as to what to do?
installing PHP in IIS can be very problematic, we have moved to suggesting XAMPP or MAMPP as an easy to use and install PHP testing environment in place of IIS.
there is a decent guide for installing PHP 5 into IIS here:
installing_php_5_iis_5_simple_steps
galen.m402136
Install PHP Thanks
I appreciate that the difficulty is great in installing PHP. The tutorial you suggest looks promising and I am working on that. The WebAssist tutorial was written for PHP 5.1, and the version available now is 5.1.17. It doesn't seem like that should make such a large difference, but a file is indeed missing. And it is an executable file at that. I have downloaded the PHP version twice (installed once). The file is not in the downloaded package. So hopefully, this new tutorial will work. If not, I'l try to work with your recommendation.
the version i see available from the php.net download page:
downloads.php
either 5.3.8 or 5.2.17
I do not see a link for 5.1.17
in Going from 5.1 to 5.2, they stopped using the php-cgi.exe file and went to using the php5isapi.dll instead.
the guide i pointed you to is intended for the php version 5.2 instead of php version 5.1
