checkout page validation... help!
Thread begun 9/01/2011 2:02 pm by info105077 | Last modified 9/29/2011 9:05 am by Jason Byrnes | 3793 views | 5 replies |
info105077
Hi Guys
I'm just a bit confused. I am trying to apply server side validation to the checkout form.
Now I'm pretty sure I add the server validation behaviour to the "confirm page" by ie
applying the validation to the ecartcheckoutform_email session, with a redirect back to
the "checkout page" where I then applied a validation show if.
My problem is regardless of the type of server validation i do the the page just fails and
redirects back to "checkout page"
worst of all it wipes out all the data in the fields previously entered
www.toners-footwear.com
any thoughts greatly appreciated
have included screen shots of the server validation and show if hoping it might help
Russ
PS have taken off validation(temporarily) from the page as would rather have orders
You are correct that the validation behavior needs to be added to the confirm page, but you should not be validating the Session collection, you should be validating the form elements
Instead of using the Session variables, expand the checkout form collection on the binding panel, and select to use form elements.
Once you have the server validation set up, you will need to add the validation show if behaviors to the checkout page in order to display validation error messages.
In the validation show if behavior, make sure to set the validation page to the confirm page.
After applying he validation show if behavior, you can set the initial value of the form elements so that entered data that is correct will be remembered.
select each form element in design view, then in the property inspector, click the lightning bolt next to Initial Value, in the binding panel, expand the Validated Entries binding group and select the corresponding binding.
info105077
UNable to see form elements on page 'confirm.php
Thank you again for the assistance Jason but I am still missing something.
In as, when expanding the bindings panel for the confirm.php page there are no checkout form elements only those within the session variables.
I see the 'checkout.php' form elements but the validations would then occur on the checkout page and not the confirm page.
I am sorry to seem thick but could you just clarify what you mean by form elements
have attached my two pages in the hope you can push me in the right direction
Russ
on the confirm page, go to the bindings panel, click the plus button and select Form Data. In the form data dialog, click the folder icon and select the checkout page.
this will add dynamic data bindings for the checkout form to the confirm page.
Web Designer Troy
Validated Entries Binding not working with eCart's checkout
I have a question on the same topic.
When the user wants to modify the checkout form in eCart, all data is still lost although I'm using the "Validated Entries" binding. (I'm also validating with Spry).
Sample with problem: checkout.php
It works fine with regular forms like here: contact.php
Am I missing something or is some other function taking place to destroy my data?
the validated entries binding is only populated when the form fails validation.
if the form passes validation, the form data is stored in session variables using the following naming convention:
eCartCheckoutForm_<element name>
where <element name> is the name of the form element.
you should make sure that the failed redirect in the server validation behavior on the confirm page passes a querystring variable, for example:
checkout.php?valid=false
then in the in initail value, use an isset() ternary expression to use either the validated entries, or session value, for example:
<?php echo((isset($_GET['valid']))?(ValidatedField("confirm","firstName")):(isset($_SESSION["eCartCheckoutForm_firstName"])?$_SESSION["eCartCheckoutForm_firstName"]:"")); ?>
