Finding an eCart value
Thread begun 8/31/2011 1:11 pm by Mike Perry | Last modified 9/01/2011 5:01 pm by Mike Perry | 6426 views | 16 replies |
Mike Perry
I need to filter an update query with an eCart column value.
I'm using a while statement to poll a table of books; one of the eCart columns is the recID for any book in the cart. I need to update the purchaseDate field for any book whose recID is in the cart.
Is there a clean way to just try and match the recID values in the cart in an UPDATE statement??
Thanks,
Mike
you can usse the cart conditional total to return the quantity of an item with a specific recID.
for example, to look up the cart quantity where recID is "22" you could use this code:
$yourCartName->ConditionalTotal("Quantity", "recID", "22")
where yourCartName is the name of your cart object.
Mike Perry
I think I understand this one; what I need is something like this:
  $query = mysql_query('UPDATE books SET purchaseDate = '.$now.' WHERE recID = '<a value in any of the recID fields in the cart object>);
Does that make sense??
you would need to hand code the recordset loop to use the value from the recordset and use this in a n if statement to trigger the update
do {
if ($yourCartName->ConditionalTotal("Quantity", "recID", $row_RecordsetName['recID']) > 0) {
$query = mysql_query('UPDATE books SET purchaseDate = '.$now.' WHERE recID = $row_RecordsetName['recID']);
} while ($row_RecordsetName = mysql_fetch_assoc($RecordsetName))
Mike Perry
do {
Thanks, Jason -- I'll play a little and see what happens!!
ETA: Which recordset loop??
that recordset loop
Mike Perry
Jason -- the code creates the following errors when called in the success.php page:
  Notice: Undefined variable: bookfair in D:\WebDev\htdocs\ccds2011\success.php on line 85
Fatal error: Call to a member function ConditionalTotal() on a non-object in D:\WebDev\htdocs\ccds2011\success.php on line 85
function updateBookspD()    {
$now=mktime();
        do    {
            if (
$bookfair->ConditionalTotal("Quantity", "recID", $row_books['recID']) > 0) {
$query = mysql_query('UPDATE books SET purchaseDate = '.$now.' WHERE recID = '.$row_books['recID']);
        while (
$row_books = mysql_fetch_assoc('books'));
Line 85 is the if statement. . .
Thoughts??
either this code is before the require once line that attaches the cart include file, or the require once line that attaches the cart include file is missing all together.
Mike Perry
This is at the top of the file:
//WA eCart Include
require_once("WA_eCart/bookfair_PHP.php");
require_once('Connections/ccds.php'); ?>
$bookfair
->GetContent();
The function declaration is the last code prior to the <DOCTYPE> declaration. There is a Clear Cart button on the page that does function properly. . .
Out to a meeting -- back this afternoon. . . thanks
it would be much easier if you would send the full php file in a zip archive so I can see the full page code in context, without the php file all i can do is guess at things that could be wrong.
