IE7 Bug - Can't select Drop Down
Thread begun 8/30/2011 2:41 pm by emily425525 | Last modified 8/31/2011 2:24 pm by emily425525 | 3735 views | 4 replies |
emily425525
I have a website that uses the CSS menu writer to create the horizontal website.
In IE7 the drop down menu disappears before you can click on an item.
surgeonsgroup/
I'm sure this is a common bug, I'm just not sure about how to fix it, and not break something else.
Thanks!
Mike Perry
Originally Said By: emily425525
surgeonsgroup/
Thanks!
Try adding a z-index value to your css for the "nav" class -- use a high number like 100. . .
neilo
The issue is likely to be the gap that appears between the level-0 and level-1 menus (currently set with a top padding of 5px).
Line 60 of your menu.css stylesheet (in the ul#cssmw > li > a, ul#cssmw > li > a:link { rule) :
padding: 5px 10px 10px 5px;
Change the top padding to zero:
padding: 0 10px 10px 5px;
emily425525
Thanks - that fixed it!
emily425525
On further testing, the padding fix did not actually fix the problem. Still looking for a solution.
Thanks!
