Glitch with server validation
Thread begun 8/30/2011 12:10 pm by iainmacdonald331081 | Last modified 8/31/2011 2:26 pm by iainmacdonald331081 | 3706 views | 8 replies |
iainmacdonald331081
Not sure what's up here - basically its the validation that checks whether or not a username or email address is already being used.
I have three registration forms, and its working fine on two, but not on one.
I've been through it a few times now, and can't see where the issue is - as far as I can tell I have everything in the right place, so hopefully its just something simple I've missed.
Have attached the file below.
Thank you.
to start with, I need to know which validation is failing.
change the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"registration10");
    die($WAFV_Errors);
this will write a coma separated list of numbers to the screen to help me see where to look.
iainmacdonald331081
I swapped that code, but it didn't seem to do anything.
Its just the server validation on the email and username fields, so I had been looking around the code:
$WAFV_Errors .= WAValidateUnique("connDatabase",$connDatabase,$database_connDatabase,"users_gsg","UserID","none,none,NULL","".((isset($_SESSION["SecurityAssist_UserID"]))?$_SESSION["SecurityAssist_UserID"]:"0")  ."","Email","',none,''","".((isset($_POST["Registration_group_Email"]))?$_POST["Registration_group_Email"]:"")  ."",true,7);
$WAFV_Errors .= WAValidateUnique("connDatabase",$connDatabase,$database_connDatabase,"users_gsg","UserID","none,none,NULL","".((isset($_SESSION["SecurityAssist_UserID"]))?$_SESSION["SecurityAssist_UserID"]:"0") ."","Username","',none,''","".((isset($_POST["Registration_group_Username"]))?$_POST["Registration_group_Username"]:"") ."",true,3);
if it did not do anything, then there is no validation failure.
that code will write a comma separated list telling me which validation has failed, if there is not comma separated list, then there is no validation failure.
perhaps, a little more clarification of the issue is in order. Please provide a detailed explanation of what is happening when you test your page versus what you are expecting to happen. all you have said so far is that it doesn't work, that is a very broad statement and does not help me know what i should be looking for.
iainmacdonald331081
This is one of the working versions:
trade_registration/
If you try to register using the email address:
iain at handprintwebdesign.co.uk
or username
trademedia
then you get the validation errors saying that they are already in use.
So I'm trying to get it to do the same thing on the page above.
OK, I understand what you are trying to accomplish, the part you are not explaining though, is how your page does not live up to expectations.
please describe how your tests are different from what you expect to happen.
it may also help to have a copy of the working page.
iainmacdonald331081
Will look at this again in the morning - tried a version not requiring a log in, and did get the comma separated list - 7 and 3.
The problem I have is that the validation isn't preventing a new user being added if they are using the same email address or username already used by someone else.
What it should be doing is checking it against the database table, and if the email address or user name typed in the form is already used in the database table, displaying error messages to that effect, as it does on the link above, with the email address or username I posted.
I have attached a copy of a page that does work.
are you logged in when you test the page?
if you are logged in, and test with the email and username of the logged in user, it will override the server validation.
Make sure that you are not logged in when you are testing this.
iainmacdonald331081
Hi Jason - apologies for not posting back earlier.
I think I managed to resolve it - I noticed some difference in some code between the one that worked, and the one that didn't, and changed:
if (ValidatedField('registration10','registration10')) {
if ((strpos((",".ValidatedField("registration10","registration10").","), "," . "3" . ",") !== false || "3" == "") || (strpos((",".ValidatedField("registration10","registration10").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
to
if ((strpos((",".ValidatedField("registration10","registration10").","), "," . "5" . ",") !== false || "5" == "")) {
if (!(false)) {
Which seemed to fix it.
Somewhere along the way, one of my log in pages now no longer works though...
See adjacent thread...
