Runtime Error - R6025 - pure virtual function call
Thread begun 8/30/2011 10:18 am by Jared Lui | Last modified 11/05/2013 12:57 pm by Jason Byrnes | 9786 views | 7 replies |
Jared Lui
Win 7 32bit - CS4 - All Super Suite extensions installed and up to date
Is this still an issue or did I miss a memo somewhere?
I've used Data Assist several times without issue in the last month. Today out of the blue I get this error for a new site. I was using 2.0.7 at the time and when the error happened I decided to get 2.0.8 to see if that fixed the issue. I uninstalled 2.0.7 first. Installed 2.0.8, replaced the library.php per the instructions and still did not help.
Tried the usual uninstall of DA, deleted the winfilecache file, reinstalled, deleted the winfilecache file again for good measure. replaced the library.php file again. And tried again with the same results. I tried uninstalling several newer extensions life security assist that I think I updated since I successfully ran DA last and installed again and again deleted the winfilecache file.
Did a search on the forums and found old issues from March of this year with no resolve. At least none noted in the threads. Last posts states no fix found and they have to be resolved via tickets. I tried several things I read in the posts and none seem to make a difference.
One thing I noted, it appears to run a bit before the crash. The Results.php is created and looks like it has quite a bit of programming done but these are the only external files it has attached (HelperPHP.php, Traditional.css and Verdana.css). I cannot recall if there are other external files or not but it appears it does begin to create the WA_DataAssist directory and some files.
I've even tried only creating the Results.php page and deselecting the others to see if it will go all the way. It craps out at the same spot regardless, even with not making any edits on any of the 4 steps.
Thanks,
Jared
av3103798
i'm having the same issue... what's the answer?
Data assist wizard does this. Tried the wincache thing... removed and reinstalled extension... to no avail. If an answer was found, I'd love to know about it. Thanks
J7HNW
Same
I have just found this thread and have the same problem. Deleted Win Cache and also closed bindings and server behavours tabs. It makes the Results page and then crashed dreamweaver with
Help please
John
you reported this issue in another thread, I started an incident for you in that thread so we can look into the problem.
mike174890
Getting Runtime Error R6025
What is the fix fo Getting Runtime Error R6025
recreate the users configuration folder and then reinstall the extensions. see step 12 of the adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
