how to create run-time variable
Thread begun 8/30/2011 3:50 am by av3103798 | Last modified 8/30/2011 7:14 am by Jason Byrnes | 1201 views | 1 replies |
av3103798
I've used Data Assist to create a search.php and result.php page similar to the tutorial.
The searching works fine, but I have one small problem.
One of the search fields is a field called "funder". It is a dropdown that shows the Funder's Name as text, but searches on the ID field, "funder_id".
On the results page, I want to show the funder, but all i can show is the funder's ID -- example, Funder:3. What I want to show is: Funder: Federal Government -- the label/name field.
So I create another recorset from the table of Funders and filter it with the results of the main 'results' recordset:
SELECT *
FROM tbl_funder
WHERE funder_ID = colname
Type: Integer
Default Value: -1
Run-Time Value: $row_rs_products['Funding_Source']
This value doesn't work for some reason. Assuming that I have the field names right, what else could be wrong? This does not return the "Funding_Source" for each result record.
I'm guessing I don't know how to properly define the "Run-Time Value" properly?
thanks for any help.
creating a new recordset is not the right way to go about this.
you need to edit the original recordset to use a join query in order to return results from the 2 columns.
see the following page for more details on creating a join query:
sql_join.asp
