Error on install on testing server
Thread begun 8/29/2011 7:18 pm by Nature Photographer | Last modified 9/01/2011 7:27 am by daniel276949 | 6198 views | 16 replies |
Nature Photographer
When trying to install PowerGallery2 on the testing server I get the following message in the diagnostic check.
cURL is not installed. Contact your hosting provider to have cURL installed.
How can I install on testing server?
Nature Photographer
Errors on Live Server as well
I uploaded the PG2 files to the live server as in the instructions but now everytime I try to apply a gallery theme or modify something I get the following error message;
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@jamesdoylephoto.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.16 (Unix) mod_ssl/2.2.16 OpenSSL/0.9.8e-fips-rhel5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at www.jamesdoylephoto.com Port 80
this_is_me
php / mysql running?
This is a typical common Apache error message which does not tell any specifics. It would need to know more precisely what you have done and caused this.
As an example, you will need a running mysql server. You certainly don't need FrontPage extension for php/mysql. Try to upload a php file with nothing else in in it but:
<?php phpinfo(); ?>
save it as phpinfo.php and upload it to the server. Then invoke it by typing
phpinfo.php
and then check if there is an entry for php / mysql a bit further down (like in my screenshot)
the error you are getting on the testing server means that cURL is not enabled in your php.ini file.
as this_is_me suggests, create the new php page with the following code:
<?php phpinfo(); ?>
and run this php info page on your testing server.
look for the "Loaded Configuration File" to find the location for your php.ini file.
in the php.ini file, find the following line:
;extension=php_curl.dll
and change it to:
save the php.ini file and restart your web server.
The error you are getting on the remote server is a very generic one, when it occurs, make note of the page that it is occurring on in the address bar, then add this code at line 1 of that page:
error_reporting
(E_ALL);
this may give us a more descriptive error message to work with.
daniel276949Beta Tester
i uploaded all the info for the ftp and the admin login info yesterday
also, i am getting the same 505 errors myself... thanks, daniel
when you get the 500 server error, make note of the page in the browser address bar, then add the following code at line 1 of that page:
error_reporting
(E_ALL);
the 500 server error is a very vague error, we need to know the real error that is occurring to be able to troubleshoot the cause.
Nature Photographer
Thanks guys, got it installed on the testing server...now just need to get you the error messages from the live server
Nature Photographer
This is the error message I get on both the live server and the testing server whenever I move with in the program.
Warning: opendir(C:/xampp/htdocs/*****/Galleries/galleries/_notes/css/themes/,C:/xampp/htdocs/*****/Galleries/galleries/_notes/css/themes/) [function.opendir]: The system cannot find the path specified. (code: 3) in C:\xampp\htdocs\****\Galleries\admin_gallery\common\functionsPHP5Compatible.php on line 31
Warning: opendir(C:/xampp/htdocs/*****/Galleries/galleries/_notes/css/themes/) [function.opendir]: failed to open dir: No such file or directory in C:\xampp\htdocs\******\Galleries\admin_gallery\common\functionsPHP5Compatible.php on line 31
Also the rendering of the images is terrible, as a photographer I would be embarassed to display these images.
Hey Jason
i'm not hearing back, do you know where my support ticket is at on the upgrade from pg1 to pg2... thanks, daniel
