Page back brings up wrong records
Hope someone can help out with this.
Basically, I have a fairly standard page that lists some records, from where you can click through to a details page, edit and delete the record.
It is built in conjunction with Security Assist - a set up where users can register, post queries, and so log in and be able to see only their queries.
Its mostly working - log in, viewing the profile etc.
The page that lists the user's queries is fine initially, but whenever you then click on to the details, edit or delete page, and go back, then its displaying the wrong records. (Although it does revert to the correct records if you hit refresh. Although obviously that's still a bit of a deal breaker!)
I've attached a couple of pages - the page that lists the queries, and the delete page - I'm not sure which is causing the problem.
Any advice on this would be much appreciated.
Thank you.
