PowerGallery2 Upgrade Help Needed
Thread begun 8/27/2011 2:04 pm by daniel276949 | Last modified 10/11/2013 12:08 pm by Jason Byrnes | 5271 views | 14 replies |
daniel276949Beta Tester
i started to upgrade my pg1 to pg2 and found a glitch in the instructions so now i am at a loss as to what to do...
Here is the instructions:
The next step is to delete the PowerGallery 1 files that you no longer need.
Using your preferred FTP application, delete all the directories in your PowerGallery directory except for the following:
Connections (this directory maintains your database connection information)
Images (this directory contains all the images used for your existing galleries)
Once all other directories have been deleted, you are ready to upload all PowerGallery 2 files to your PowerGallery directory.
this part was straight forward until i got to this set of instructions...
Make sure not to overwrite the Connections folder and images folders. To be safe, you may want to delete those directories from the PowerGallery 2 files prior to uploading.
Problem, in looking for the connections and image folders, i did not find any by that name and i was not sure if they were just not included or maybe they would be created during install/upgrade so i decided to stop, just to be sure....
So, what should i do from this point forward to do the install/upgrade from pg1 to pg2...
Justin HoodWebAssist
Neither connections nor images should exist in the V2 files. Ignore that step and copy over what you do have.
Where are you reading those upgrade instructions from?
Thank You
i had assumed that but wanted to be sure before i uploaded vsn 2....
here is the link to the page that had the info....
upgrading_v1-v2.php
Have a great 2011
upgrade from v1 to v2 failed
when i deleted the files and then uploaded the new files and then ran the upgrade to vsn 2 none of the gallerys images are there...
i followed the directions once i knew for sure about the upgrade and all the gallerys are void of any images...
in checking the images directory all the images are there however it is just not connecting... not sure what to do to fix it...
do i need to move all the images to a new directory other than images... also our entire server was upgraded to the latest php version if that make a difference...
thanks, daniel
i should note the following:
everytime i log in it keeps going to the settings directory and the serial number keeps going blank and i add it back in and it accepts it and then i log out and go back only to find the process did not take??? thanks again, daniel
Are you using a beta serial number or did you purchase the live product? I'll open a support incident so that you can share your phone number, serial number, and ftp information with an engineer so that we can look into this further with you.
Hi Ray
yes, i did buy the upgrade over the weekend and used the new serial number...
go ahead and send me an incident link and i can get you all the login for ftp and admin...
Originally Said By: daniel276949
thanks, daniel
When you say: 'it is just not connecting', what action are you performing that isn't connecting? Are you loading/previewing the gallery itself? And what browser are you using?
Thanks Daniel!
a support ticket was opened yesterday ...
i am still waiting on results from that also...
here is the url to the home page
family.plushkin.net/ from there you can click on links to the album...
here is the link to the albums
home.php ... if you click on one of the images you can see what happens...
here is a link to one of the albums
index.php?gallery=1&theme=dark
have to say it is very frustrating to have an album that worked just fine and then to upgrade to vsn 2 and everthing crashes and burns... when i installed the beta versions it worked just fine...
thanks again... daniel
What happens when you visit Admin and access Manage Images for any one of those galleries?
