Debugging paypal checkout
Thread begun 8/24/2011 10:14 am by webmaster422158 | Last modified 8/25/2011 7:20 am by Jason Byrnes | 2153 views | 3 replies |
webmaster422158
I've setup up an eCart section (with the paypal pro gateway) on my site using Dreamweaver CS4 and am testing it using IE 9. The cart uses static items and works fine until I hit the checkout after confirming the order info. When I confirm the info I get the checkout failure page "Transaction Not Completed", but no debugging info. I've added the debug info option from the bindings and uploaded the edited failure page and updated WA_eCart directory.
I don't know why the transaction is failing and I don't know why I am unable to see the bug report on the failure page. Any help would be appreciated.
paypal payments pro has 2 different payment methods:
1- PayPal Direct Payments - Customer enters credit card information on the checkout page
2- PayPal Express Checkout - customer is directed to the paypal site and logs in
depending on which payment method is used, there are different binding groups to add to the bindings panel through the Local Checkout binding option.
another way to get the paypal request and response it to add the following code to the page:
@session_start();
     echo
"<p>Direct Pay: <br />";
     echo
"Full Request: ".(isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a")."<br /></p>";
     echo
"<p>Express Authorize <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br />";
     echo
"<p>Express Process: <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>";
NOTE: The full request and full response will contain sensitive information that should be removed before posting here.
webmaster422158
Thank you, that gave me a verbose response above the error.
The error message I received after doing this was "security header is not valid". The gateway was setup as "paypal process express checkout". Our account type is listed as "business" in our profile.
If more information from the response is needed let me know and I will edit and post it.
The error "security header is not valid" means that there is a problem with the PayPal API Username, Password and Signature you have entered.
it usually happens if you use Sand Box API Credentials but set eCart to use the live server, or vice versa.
double check that you are using the correct API information.
