database configuration
Thread begun 8/24/2011 6:52 am by gunnar.andersson426689 | Last modified 9/02/2011 9:38 am by Jason Byrnes | 2344 views | 5 replies |
I have just started to use HTML Editor and Filemanger.
The editor works just fine but the filmanager shows an empty WEBpage
when clicking the icon.
( HTML error 500 internal server error )
I have MySQL 5. and PHP 5.2. and a working connection to the database.
Should ther be a manualy configred dataset to the page and a manualy configured
databasetable or is that automaticaly done when installing HTML Editor?
Hello!
No contact last friday but now is your Skype contact configured
Is 9 and 11 am PST tomorrow (2011-08-29 )acceptable for You to try to call. I will be att the computor
Regards / Gunnar Andersson
Please update the support incident with your information and contact request. The back end incidents are handled by a separate group of engineers than the forum posts.
directory error
Thank you for all help but someting is still confusing?
Upload with filemanager works OK BUT the "root" directory is set to and created to upload.
( I have tried to cange everywere I know in the setup but upload is still used)
When I chose an image in HTML-editor ( via FileManger ) it is OK if the image is in
the directory upload but if it is in upload/images the link transfered to HTML-editor menu
is uploadimages/..... without a / between upload and images.
If I edit a / in the text the file is loaded correctly into HTML-editor.
Where should I change to delet/rename the upload name of the directory
Regards
Gunnar Andersson
in the webassist/kfm folder, you should see a configuration.php file. Open the configuration.php file and you can adjust the setting by changing the $kfm_userfiles_address and the $kfm_userfiles_output setting.
