And OR
Thread began 8/23/2011 12:15 pm by sandhills404774 | Last modified 8/23/2011 12:27 pm by Lon Winters | 998 views | 1 replies |
sandhills404774
And OR
First, I browsed the Forums to find an answer to my question. I had no luck.
Second, I have a search form that I want to have an "AND" or "OR" search capability. So, I want to be able to enter shoes and socks into the search field and return both. The column that I am searching contains only one item per row. In other words shoes and socks won't be found in the same column.
Any advice would be appreciated.
Lon WintersBeta Tester
I would use a drop down with ther items; shoes, socks and shoes and socks. The values would be shoes, socks, and for the third there's an operator you can use that means "All". With ASP it was a percent sign, not sure if that works in PHP. Then construct your recorder using OR that would match one of the three values.
