Search form stopped working
Thread begun 8/23/2011 8:29 am by sandy170299 | Last modified 8/23/2011 10:02 am by Jason Byrnes | 2408 views | 4 replies |
sandy170299
This search form has stopped working. I have not touched the form in a couple of months, and now it's not pulling up any results, even though I know I'm entering valid data.
Also, why do you not allow RAR files to be uploaded for the forums?
Thanks!
If it was working before, I would start by looking at the data.
the recordset being used has a couple of INNER JOIN statements.
using an INNER JOIN means that a result will only be returned if there is data in both tables to satisfy the join criteria.
for example, the first inner fjoin:
FROM dbo.tblApplicationScores INNER JOIN
dbo.tblScoringGroups ON dbo.tblApplicationScores.scoringGroupID = dbo.tblScoringGroups.scoringGroup
if there is not a record where:
no result will be returned.
try changing the join types to see if that effects the results using LEFT, RIGHT or OUTER joins.
sandy170299
I took away the inner join statement from all of the tables, and it's still not working.
sandy170299
Actually, using an inner join did return results - at least in the query, because the tables are fully populated with info from the other tables, if that makes sense.
