Search one table using another table as a dropdown
Thread begun 8/21/2011 5:12 am by superpac250441 | Last modified 8/22/2011 11:20 am by superpac250441 | 1801 views | 2 replies |
superpac250441
Is it possible to have one table to be used as a look up table to search another table field to see if the exact term selected in select drop down from the (look up) table has the same term in the field of the other table?
I basically want to use a drop down list of different types of expertise to search a practitioner database field to see if that expertise term is present.
Can this be done?
Many thanks
yes, you could create a recordset to return all the columns from the expertise table.
then create a select list on the page, in the property inspector, click the dynamic button and configure the options from recordset section to use the recordset you just created.
you can then use this select list in data assist search
superpac250441
Excellent, thanks very much!!
