change date format on multiple update
Thread began 8/19/2011 1:54 am by georgina_barrett_187762 | Last modified 9/08/2011 6:36 am by Jason Byrnes | 2127 views | 5 replies |
I need to display dates in 'd F Y' format and this is the format that users will input dates into the database. When inserting them in a single insert/update I use:
".((!empty($_POST["DateAdded"]))?date("Y-m-d", strtotime($_POST["DateAdded"])):"") ."
to convert the date back into the format for the database to store it.
The problem is with multiple inserts/updates I can display it in the correct format but how do I upload the date and change it to Y-m-d?
This is my code:
// WA DataAssist Multiple Updates
if (isset($_POST["Update_x"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_ConversationID");
$WA_connection = $flybuy;
$WA_table = "Conversation";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "ConversationID";
$WA_fieldNamesStr = "DateAdded|Type|Type2|HandledBy|ConText|Action";
$WA_columnTypesStr = "',none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_flybuy;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("DateAdded2", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("Type", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("Type2", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("HandledBy", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("ConText", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("Action", $WA_multipleUpdateCounter) ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
please compress the php page to a zip archive so i can see the entire page code in context.
Thank you. Zip file is attached. I have changed the format from 'd F Y' to 'd M Y'.
Complaint_Update.zip
ok, all of the date form elements in the repeated region are named "DateAdded2_<int>" where <int> is an incrementing integer.
we can use the substr() method to look at the elements name, and if the first 11 characters of the name are "DateAdded2_", use the date function to convert the date format
add the following code at line 1 to accomplish this:
if($_SERVER['REQUEST_METHOD'] == "POST") {
    foreach(
$_POST as $k => $v) {
        if(
substr($k011) == "DateAdded2_"$_POST[$k] = date("Y-m-d h:m:s"strtotime($_POST[$k]));
Thank you very much - I don't fully understand the working - but it works like a dream. Thanks again
OK I'll give a brief explanation of each line, to hopefully make it a bit clearer.
the first line is an if statement that causes the code to only execute if there is a form post:
the next line creates a loop using the foreach() construct that goes through each form element, it breaks the form element name into a variable named $k and the element value into a variable named $v:
foreach($_POST as $k => $v) {
the next line is really 2 lines, the first part looks at the element name which is stored in the $k variable, it takes the first 11 characters of the element name to see if it is equal to "DateAdded2_" using the substr() function:
if(substr($k, 0, 11) == "DateAdded2_")
if it is equal to "DateAdded2_", it performs the date format to reformat the using the Y-m-d h:m:s format that is expected by the MySQL database
$_POST[$k] = date("Y-m-d h:m:s", strtotime($_POST[$k]));
