Menu CSS is not showing
Thread begun 8/18/2011 10:48 pm by debbie295402 | Last modified 8/19/2011 11:06 am by Jason Byrnes | 7787 views | 10 replies |
debbie295402
I've hit a wall. I've been using CSS MenuWriter forever, but today I did something that doesn't allow the css to show on template pages. Please see www.dsh-solutions.com for the correct page, then just hit any other sub page and the css for the menu isn't showing. Not sure what I did and I've looked at the code for 2 hours now to make sure that the paths are correct. I've checked links and I'm at a loss. Anyone with a fresh pair of eyes willing to give this a go? Or is it a bug?
neilo
Only the working page that you link to has been given a <!DOCTYPE . . . > declaration.
They work fine in Firefox, but some browsers will require the DOCTYPE declaration on each page.
nielo is absolutely correct about the doctype.
IE is the most notorious for needing to have the doctype specified.
when no doctype is specified, IE will go into "Quirks Mode".
In "Quirks Mode" IE will use the IE 5 rendering engine which just barely has support for CSS1
quirksmode.html
debbie295402
Actually, they all have a doctype of <!doctype HTML> (html5) but it is located after the template text that dreamweaver put in for it's template use. I've used dreamweaver templates on all my sites and never had an issue... I've removed and readded the menu in case I screwed up the xml file somehow, but nada.
Here's the head info if this helps:
<!DOCTYPE HTML>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=UTF-8" />
<!-- TemplateBeginEditable name="doctitle" -->
<title>Zonta Club of Santa Clarita Valley&nbsp;|&nbsp;&nbsp;</title>
<!-- TemplateEndEditable -->
<script type="text/javascript" src="../scripts/jquery.js"></script>
<script type="text/javascript" src="../scripts/cufon.js">
</script>
<script src="../scripts/TeXGyreAdventor_400.font.js" type="text/javascript"></script>
Cufon.replace('h1'); // Works without a selector engine
Cufon.replace('#menu li a'); // Works without a selector engine
//Cufon.replace('#sub1'); // Requires a selector engine for IE 6-7, see above
</script>
<link rel="stylesheet" href="../styles/reset.css" />
<link rel="stylesheet" href="../styles/960.css" />
<link rel="stylesheet" href="../styles/style.css" />
<!-- TemplateBeginEditable name="head" -->
<script type="text/javascript" src="../CSSMenuWriter/cssmw/menu.js"></script>
<style type="text/css" media="all">
@import url("../CSSMenuWriter/cssmw/menu.css");
</style>
<!-- TemplateBeginEditable name="menu_ie" -->
<!--[if lte IE 6]>
@import url("../CSSMenuWriter/cssmw/menu_ie.css");
</style>
<![endif]-->
</head>
the doctype MUST be the first tag on the page, if IE sees any html code before the doctype, it will go to quirks mode:
<!-- InstanceBegin template="/Templates/subPage.dwt.php" codeOutsideHTMLIsLocked="false" --><!DOCTYPE HTML>
needs to be rearranged to:
<!DOCTYPE HTML><!-- InstanceBegin template="/Templates/subPage.dwt.php" codeOutsideHTMLIsLocked="false" -->
debbie295402
That was the solution. Thanks so much!!
Any idea offhand why dreamweaver would start creating templates this way? This was working throughout but during one of the updates (not sure which one) I got this...
Sorry, I've not run into an issue with Dreamweaver doing that before, not sure why it would start doing that on you.
debbie295402
The thing is that all new pages created from the template need to have the <!DOCTYPE HTML> added. Very weird. probably something I'm missing. Thanks.
send a copy of your template in a zip file,I may be able to see the cause of the problem if i can see the code.
debbie295402
I just found that the opening <html> tag was missing so it screwed up the template and where it put it's editable/lock language. Fresh eyes and no panic really makes a difference!
Thanks for the offer and the help!
