form is not working with added additional fields
Thread begun 8/18/2011 1:09 pm by daniel276949 | Last modified 8/19/2011 11:39 am by daniel276949 | 3031 views | 5 replies |
daniel276949Beta Tester
contactus.php
in using this form, i added a few additional fields and when i run a test none of the fields come through in the email... i am not sure what i am doing wrong or leaving out... i followed the directions on the insert additional fields...
would you take a look at the code and tell me what i am doing or not doing that is wrong?
thanks, daniel
for each additional field you are adding you are using the name "Phone_Number"
<label>
Boy and/or Girl<br />
<input type="text" name="Phone_Number" id="phone_number" />
</label>
each form element must have a unique name and ID:
<label>
<input type="text" name="Boy_and_Girl" id="Boy_and_Girl" />
</label>
my bad...
i am so so sorry... i uploaded the wrong file by mistake, but, your response showed i did do it correctly...
thak you, daniel
OOP's, i spoke too soon... again
form is showing error messages before anyone adds anything to the form?
contactus.php
attached is a screen shot of the error messages...
those are the spry validation errors.
if you look at the origianl contact form, the following code is before the <body> tag:
script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="SpryAssets/SpryValidationTextarea.js" type="text/javascript"></script>
<style>
.textfieldServerError {
display:block;
margin:0px;
color:#CC3333;
border: 1px solid #CC3333;
</style>
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationTextarea.css" rel="stylesheet" type="text/css" />
and this code is before the </body> tag:
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur"]});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "email", {validateOn:["blur"]});
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"], minChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>, maxChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur"]});
</script>
these code blocks are needed for the spry validation to work properly.
Fantastic... Thanks Jason
i did not even see that when i applied the template to the contact us page...
