Need help with shipping rule
Thread begun 8/18/2011 4:52 am by Base5 Designs | Last modified 8/23/2011 1:40 am by Base5 Designs | 4212 views | 6 replies |
Base5 Designs
Hi there am hoping you can pint me in the right direction.
My client is a wine warehouse the shipping works out like this:
there is a flat rate per case (stored in my shipping table)
the flat rate applies to 1 case which holds up to 12 bottles, so for example
£12 for 1 - 12 bottles (1 case) 12*1
£24 for 13 - 24 bottles (2 cases) 12*2
£36 fr 25 - 36 bottles (3 cases) 12 * 3
and so on
ive followed the guide on how to create the session variable for the shipping rate (shiprate).
is it possible to create this rule? and if so how?
thanks for your time
Sounds like a pretty simple simple quantity discount.
you will need to create a separate rule for each quantity break on the shipping tab of the eCart object, for example:
1 - 12:
Triggers:
"SubTotal for any column"
If the Subtotal for column "Quantity" is ">" a value of "0"
AND
If the Subtotal for column "Quantity" is "<=" a value of "12"
Calculation:
Flat rate charge of "12"
the other rules will follow the same pattern, just changing the quantity and the flat rate charge.
Base5 Designs
Hi Jason thanks for your reply
i can easily add the rules as static, but would prefer it to be dynamic if possible
for example if i wrote the following in php:
//quantity is the number of items,
//shipcost is the cost of shipping 1 box stored in a session variable
myshipping = function($quantity, $shipCost){
$boxHolds = 12;
//get number of complete boxes
$completeBoxes = floor($totalQuantity / $boxHolds);
//check too see if there are extra bottles
$extraItems = ($totalQuantity % $boxHolds);
if ($extraItems >0){
$completeBoxes +1;
$myshippingAmount = $completeBoxes * $shipCost;
return($myShippingAmount);
i could return either complete boxes from the function and have the rule calculate the shipping or return an actual cost for the shipping
would it work and how would i create a shipping rule using this function?
assuming your function returns the correct amount, store the $myShippingAmount in a session variable, then use the session variable in your shipping rule
set the shipping rule to use the trigger:
Number of unique items in the cart > 0
and a flat rate shipping of '$_SESSION['myShippingAmount']'
Base5 Designs
Hi Jason
I'm still struggling with this
the steps i have taken are as follows
in my ecart object i have a colulmn called totalbottles which sums up how many bottles need to be shipped (the number of bottles per product is stored in my product table)
the cost of shipping 1 case is in a recordset that is filtered by the country code (in fact its the same table that stores all my countrys for the select list)
i have a function as described earlier that works out the shipping rate (i have checked this function and it does work as expected if i put in static values)
on my checkout page i have created a session variable to hold the returned value from my shippingcost function
to the function i pass the cost of shipping one case and the totalbottles amount
$bottleAmount = $eCart1->DisplayInfo("TotalBottles");
$shippingCost = $row_rs_saleparams['shipcost_scn'];
$shippingAmount = myshipping($bottleAmount, $shippingCost);
this i then store in a session variable
if(isset($_POST["Checkout_x"])) {
$_SESSION["myShippingAmount"] = "".$shippingAmount ."";
when i get to the confirm page no shipping is displayed.
i'm not sure if i understand the flow of the checkout pages correctly
if the checkout form submits to confirm.php then i am guessing the session variable will not be set as the code is not on that page,
If i put the all the code to set the shipping on confirm.php then the session variable wont be avaliable to work out and display the shipping cost. (as it will need a page refresh to pick up the session variable)
if you could give me a detailed workflow of what to put where i would appreciate it.
Base5 Designs
hi Jason
I have been playing around some more and seeing what values were being echoed out
it seems that my calculation in ecart for total bottles is not being calculated correctly
i have the calulation named total bottles which is bottles * quantity
however this only seems to work on a per row basis how do i get the total amount of bottles for the whole cart???
Base5 Designs
managed to get it working, not quite sure what i did to get it working, but its working !!! is all thats important for now!!!
