Search by exact string of words
Thread begun 8/17/2011 11:45 am by johnb | Last modified 8/18/2011 9:49 am by johnb | 3267 views | 6 replies |
johnb
I have a clients site that has thousands of products. The client would like the search results to show only the exact combination of words. For example if they currently search for RED CAR then they'll get every single product that has the word RED or CAR. They want instead for it to always bring back only the Exact phrase RED CAR. We have noticed by putting quotes around "RED CAR" that it will perform the way they want but they can't expect all users to know how to do that. Is there something that I can change in the code that will make it always reveal only the exact phrase mach when searched?
BTW This is Powerstore 3
you can try adding the following code at line 1 of the products_Results.php page:
if(isset($_GET["S_ProductName"]) && $_GET["S_ProductName"] != "" && substr($_GET["S_ProductName"], 0,1) != "\""  && substr($_GET["S_ProductName"], -1,1) != "\"") {
$_GET["S_ProductName"] = "\"".$_GET["S_ProductName"]."\"";
it will force quotes around the search string.
it may be better, though, to add a message to the FAQ section explaining how to do an exact match search.
johnb
I realize this is a tad different spin on the question above but what if they wanted to return RED CAR results bringing up only products that use both words and not necessarily in order?
well, if you used the code i supplied before, you would not be able to do that
the search is configured to use a space as the OR separator:
RED CAR would search:
WHERE column LIKE '%RED%' OR column LIKE '%CAR%'
it uses ", " (coma followed by a space) as the and separator:
RED, CAR Would search:
WHERE column LIKE '%RED%' AND column LIKE '%CAR%'
if you force quotes around all search strings, you loose that flexibility, which is why I suggested an FAQ entry to explain the full string search as a better alternative.
If you dont modify the code, you can do fairly complex searches like:
"RED CAR", "WHITE TRIM"
this would search for
WHERE column LIKE '%RED CAR%' AND column LIKE '%WHITE TRIM%'
johnb
Would there be a solution to always force the space to be a comma similar to forcing the result to have quotes around it as in the fist example? I understand you couldn't do both quotes and comma rewrites.
I really appreciate your quick help on this.
on the products results page, change the following line of code:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_GET["S_ProductName"]))?$_GET["S_ProductName"]:"")  ."","WHERE","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_GET["S_ProductName"]))?$_GET["S_ProductName"]:"")  ."","WHERE","Includes","%20",",%20","%22","%22",0);
this will change it so that " " (space) is used as the AND separator and ", " (comma space) is used as the OR separator.
johnb
I really appreciate your help Jason! I hope this thread will benefit others with this need as well. It works famously!
