Adding access rules
Thread began 8/16/2011 4:18 am by daniel387105 | Last modified 12/09/2011 7:12 am by Jason Byrnes | 6254 views | 36 replies |
daniel387105
Adding access rules
Hi
I wont to add a access rule so that a use that a grant acces to can only see "Add user" all other user will not see this Add User how is this done thanks
Home
Add User
My Information
Live Shouts
Streaming Setup
Downloads
FAQs
Log Out
John LangerBeta Tester
Create your access rule (if not already created)
Then highlight the words "Add User" on the page. (This only seems to work for me in design view).
In the server behaviours panel click the plus button
choose webassist > security assist > show region
In the pop up dialogue box choose your access rule and click OK
That should do it.
daniel387105
Thanks How do i Create access rule and can this be used for more then one user? also the word add user is a css link so i take it i would select all ?
Sorry, I thought you had already got that far.
To access the Access Rules Manager, go to WebAssist > SecurityAssist > Manage Site Access > Access Rules Manager
Click the plus button to add a rule
To save me typing it all out click the help button and it will work you through it. here's a direct link to that help page access_rules_mgr.html
Post back if you still get into difficulties.
daniel387105
Hi John
i have a rule for lodg in a user so would i edded this or make a new rule or lodg in as admin?
Basically, yes.
If you don't want anybody logged in as user to see the link, then make another rule, you can call it what you like but admin is fine, and then apply that rule to the link. Then only those logged in with the admin privilege would see it (the link that it).
daniel387105
Thanks John
ok this is the first time i have done this sort of thing so what condition would i put ?im lost at this bit sorry
Conditions + Allow If
value???? server variables = suth_user?? is that right
Criteria????
Compare To???
Or can i copy the user loggin as user and change name then what?
I have set the two pages to loged in as admin now how do i let it know who is admin?
This can be a complex subject.
I learnt how to do it by watching some interactive tutorials by Mark Fletcher. These are for Security Assist version 1 and I'm assuming you are on V2 but the principle is basically the same.
As well as the tutorials there is also a pdf download you can read.
Follow this link and then click on Archived Documentation on the right. Towards the bottom there is a subject of User Level Authentication. Just follow the videos in order and it should put you in the correct direction. Or read the PDF doc.
daniel387105
Thanks John I will give you a shout out on my online radio station :)
You'll see in those videos that it talks about downloading files. Not sure if they still exist or not but you don't need them. Just watch and learn... :)
