Check for duplicate records
Thread begun 8/14/2011 11:34 pm by davegw | Last modified 7/25/2012 7:58 am by jon211112 | 5617 views | 7 replies |
davegw
How can I use Form Toolkit to check for duplicate records in a unique field? I could not find it in the list of server validations. It must be checked when inserting a new record or updating an existing record. I'm using DW CS5.
see this thread for details:
showthread.php?t=19462
davegw
Thanks Jason, works like a charm! I had to move the validation code block between the recordset & insert form behavior as suggested in the thread.
davegw
This detects duplicates when inserting a record, but when an existing record is updated it complains on my error page that the field entry already exists, when the unique field has not been changed. A condition probably needs to be applied to the WA Server Validation entry that checks that $totalRows_recordsetname numeric range is from -1 to 0.
in my case:
$WAFV_Errors .= WAValidateNM($totalRows_rsChkRefNo . "",-1,0,0,",.",true,4);
Code blocks are in this order:
Recordsets
WA SV
Update Form
when the user logs in a session with their id is stored, if the ID in the recordset is the same you could bypass the check.
this example assumes that the session created by the login is "ID" and the name of the ID column in your database is "ID"
$WAFV_Errors .= WAValidateNM((($row_rsChkRefNo['ID'] == $_SESSION['ID'])?0:$totalRows_rsChkRefNo) . "",-1,0,0,",.",true,4);
jon211112
Hi Jason
I have the same problem but am using the latest Data Bridge so I think the syntax has changed?
I have a form which allows the member to update their details. Their email address is used to log them in (with password of course) and the form allows them to change all their details including their email address. I need to check that the email entered is not already in the database, but if they leave it as it is then it should allow it.
At the moment it's checking the email is unique and giving the error because it's found it in the database. But the record it found is the one for the person logged in.
I need to be able to make the validation work only if the field has changed. If it matches the field in the record then it should either not update it or update it in the normal way but without triggering the error.
I hope this is straight forward.
Many thanks
Jon
In data bridge, there is a new validation type for Unique Database value.
In the unique database value validation, you select the column to be unique and the form element used for entering it.
It also has a section to select the ID column, the security Assist authentication stores the userID in a session variable at login, in the validation, bind the ID value to the security assist ID session variable, this will allow the user to reuse his email address.
jon211112
Perfect, thanks Jason.
