Super Suite install order
Thread began 8/13/2011 9:55 am by Airfox | Last modified 7/12/2013 12:11 pm by Jason Byrnes | 3251 views | 4 replies |
Airfox
Do you have a recommended install order for Super Suite?
I'd like to avoid compatibility issues and the repeated prompt asking 'file xxxx is newer than the one you are installing, would you like to replace it with this older file?' coz irritatingly Adobe didn't include a 'no to all' option.
thanks
DarylBeta Tester
I cant comment on the order aspect although I believe that there is only an issue with Form Builder/HTML Editor/Unniversal Email, but that is explained in the downloads area.
With regard to the message, you will get that every time you add an extension after your first one. When it comes up, click "Yes to all" - this was recommended by WA elsewhere on the forum.
as Daryl suggest, you can click the yes to all.
the only suggestion i can make to install order is that these extensions should be installed last in this order:
CSS Form Builder Support Release 2
HTML Editor 3
Form Toolkit
Security Assist 2
only those 4 extensions have an order to be installed in, and they should be the last 4 installed.
anonymous
Install order
What is the correct install order for:
Design Extender
Data Bridge
and Ecart
Dreamweaver CS6
On mac OSX v 10.8.4
the order i suggest is:
eCart
free tools
Design Extender
Data Bridge.
in reality, though, as long as eCart is not installed last, the order does not matter
