ie9 issue
Thread began 8/12/2011 6:36 pm by gruant2000381341 | Last modified 8/17/2011 3:05 pm by gruant2000381341 | 2414 views | 8 replies |
gruant2000381341
ie9 issue
I am running PCMS 102 version with the unlimited license.
When in the home page of the admin area using internet explorer 9, the tabs for all the pages will not collapse.
pics of what i mean attached...1 of what it looks like on all other browsers I've used, and the other on ie9
gruant2000381341
rut roh....just noticed that pretty much all buttons in ckeditor that have popup windows won't work either
create table..insert images..insert image buttons..create links
power cms is not IE9 compatible at this time, you will need to use it with IE8, fire fox, safari or chrome.
gruant2000381341
is there a fix in the works? I noticed you said...at this time
Yes, we will be updating Power CMS to be compatible with IE9, though I do not have date on when this will happen.
esmsBeta Tester
Hello,
Sorry to interupt.
Just to check, does this mean if a site owner has IE9 on his / her PC, s/he won't be able to update their site at present?
they will have issues with the CMS Admin section using IE9, they should use a different browser when accessing the CMS Admin section.
gruant2000381341
yes esms, if the person tries to use ie9....several of the tools do not function. I am surprised this hasn't been noticed yet. maybe it has been posted but I couldn't find it anywhere
i better add that changing text works just fine...its some of the tools that require popups are misbehaving...like the link creator, table interface, images..that stuff
gruant2000381341
what would be the cause of the original post (the tabs on the home page not collapsing)...that has nothing to do with ckeditor
