Shipping Charge
How do I set up my shipping charges? I want to charge say $1.50 x weight.
Thanks.
Thanks.
in the eCart object, create a new shipping rule on the shipping tab.
set the trigger to:
"subtotal for any cart column"
if the subtotal for column 'TotalWeight' is '>' a value of '0'
Calculation:
"Based on multiple of column subtotal"
Subtotal of column 'TotalWeight' 'times' '1.50' 'plus' '0'
If I wanted to make that shipping rule discounted if the qty is > 1, how would I do that?
on the discounts tab, set the following rule:
triggers:
"subtotal for any column" - if the subtotal of column 'quantity' is '>' a value of '1'
calculation:
Flate rate discount of '$this->GetShipping()'
I can't enter anything in the Calculation field. It only lets me choose from a drop down list.
make sure you are using the Flat Rate calculation type.
I typed this in the Flat Rate Calculation field: '$this->GetShipping()'
Now it only charges the shipping for 1 item. The second items shipping charges are not calculated.
I basically just want to offer a $3 discount for each item over a qty of 1.
you said before that you wanted to discount the entire shipping if quantity was greater than 1.
to discount $3 for each item over a qty of 1, use the same trigger:
for the calculation use:
subtotal of column 'quantity' times '3' 'minus' '3'
