Removing the Add Gallery button
I would like to hide the Add Gallery button from the admin section and have tried editing the CSS - unsuccessfully. Would you please tell me what code I need to change?
Thank you
Thank you
in the admin_gallery/choosegallery.php file
change:
<a href="#" id="addgallery">Add Gallery</a>
<!--<a href="#" id="addgallery">Add Gallery</a>-->
I tried commenting it out previously but the "Add Gallery" button seems to be connected to other code on the page. When you delete or comment out the code you can no longer select any galleries: the "Edit this Gallery" buttons are no longer click-able (but they light up on mouse-overs). Any other suggestions?
ok, instead of commenting the link, either remove the add gallery text:
<a href="#" id="addgallery"></a>
or set an inline style to set the visibility to hidden:
<a href="#" id="addgallery" style="visibility:hidden;">Add Gallery</a>
