Help With Shipping Costs
Thread begun 8/11/2011 4:43 am by laura_ellis427550 | Last modified 8/15/2011 10:12 am by laura_ellis427550 | 3134 views | 7 replies |
laura_ellis427550
I'm after some help with shipping costs. I'm creating a shop with ecart that sells fabric by the metre. The client initially wanted a flat shipping cost per metre purchased which is what I included when creating the shop. However, they've now changed their mind and want to charge for shipping based on quantity bought, as follows:
For 1m = £2.00 shipping
For 2-20m= £5.00 shipping
For 21-49m = £10.00 shipping
For 50m or over = free shipping
How and where do I go about changing the shipping rules to reflect this change?
Many thanks in advance,
Laura
is quantity the same as meters in this cart?
you can congure shipping charges in the eCart object on the shipping tab.
with your cart display page open, go to Window -> Server Behaviors, in the server behaviors panel, click the eCart Object to open the eCart object editor.
go to the shipping tab to set shipping rules.
your shipping rules will use the "Subtotal for any column" option for the trigger
and a flat rate shipping charge.
for example, to set up the 1m charge:
triggers:
Subtotal for any column - if the subtotal of column 'Quantity' is '=' a value of '1'
flat rate charge of 2
for the 2 - 20 charge:
triggers:
Subtotal for any column - if the subtotal of column 'Quantity' is '>=' a value of '2'
AND
Subtotal for any column - if the subtotal of column 'Quantity' is '<=' a value of '20'
flat rate charge of 5
laura_ellis427550
ratersa 917
They are the same, yes. Thanks, I'll give it a go.
laura_ellis427550
Shipping Exception
Hi Jason,
That worked fine - thanks. However ...
I will also be adding the option to add samples of fabric to the cart, for which there is no shipping charge. At present the shipping rules will apply the same charges to the samples as to the actual fabrics and I can't work out a way to apply an exception to them. Instead of shipping they will have a flat charge applied to them when someone orders more than 5. I assume that I can cater for that charge in the "Charge" section of the eCart Object but how do I get around the shipping issue?
you would need to add a new column to the cart object called "shippable".
for the items shipping should apply to, set the shippable column to 1 in the add to cart buttons.
for the items shipping should not apply to, set the shippable column to 0 in the add to cart button.
then in the shipping rules, you will need to use the custom condition trigger option and add the following code:
$this->ConditionalTotal("Quantity", "shippable", "1")
for example, the trigger for the 1meter rule will be:
$this->ConditionalTotal("Quantity", "shippable", "1") == 1
the trigger for the 2 - 20 meter rule would be:
$this->ConditionalTotal("Quantity", "shippable", "1") >= 2
AND
$this->ConditionalTotal("Quantity", "shippable", "1") <= 20
laura_ellis427550
Shipping
Hi Jason,
The first set of shipping rules that I applied worked fine. However, when I add the second ones with the custom condition, I get a totally blank page when I preview it in a browser. What will cause that to happen? I've attached the page that the cart has been applied to.
Thanks,
Laura
sorry, i gave you bad syntax for the custom condition, instead of:
$this->ConditionalTotal("Quantity", "shippable", "1") = 1
the custom condition should be:
laura_ellis427550
Great - all working now. Many thanks.
