post variables from bindings panel
Thread begun 8/10/2011 4:39 pm by AlaskaTom | Last modified 8/11/2011 7:03 am by Jason Byrnes | 2302 views | 3 replies |
AlaskaTomBeta Tester
This is something that bugged me forever, and I was wondering if there is a solution.
WA extensions always add form variables to the bindings panel, which is fantastic.
However, those variables are not 'translated' in DW design view.
ie they show up as little 'php' squares, instead of {POST.variable}.
If I add the form variable directly to the bindings panel manually, using the plus icon, it works fine.
The only difference is the format of the generated code.
WA puts the post variable in the format
<?php echo((isset($_POST["variable"]))?$_POST["variable"]:"") ?>
Where the default DW way displays as
<?php echo $_POST["firstname"] ?>
Either way works fine programatically, but its just nice to see the translated value in DW instead of the little php square.
Is there a fix, or a setting I have wrong?
Thanks!
Tom
no, there is not a fix for this, DW does not translate the syntax we use:
as a post variable.
the reason we use this syntax is to prevent PHP errors from occurring.
if you use the Dreamweaver Syntax:
a error will occur on the page if the firstname POST variable does not exist.
we use the isset syntax:
to prevent that from happening.
I am sorry to hear that! I was hoping there was some simple fix.
I often manually enter the form elements into the bindings to prevent that.
You would have to have your error reporting set pretty low for that to trigger a error, though, since its a just a warning, not a fatal error.
Thanks for the quick response!
Tom
during development, i always leave my error reporting set to E_ALL (Show All Errors and Warnings). using the isset() method prevents errors that would break the redirects in the server behaviors.
