PowerCMSBuilder Admin - Can't upload Pictures
Thread began 8/10/2011 7:36 am by markymark44 | Last modified 8/11/2011 7:52 am by Jason Byrnes | 1461 views | 3 replies |
markymark44
I can log in to the Admin and update text, but when I try to load an image, the popup window "hangs" and I see an exclamation point in the bottom left hand corner - the info attached is:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; chromeframe/13.0.782.112; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2; .NET4.0C; BOIE9;ENUSMSNIP)
Timestamp: Wed, 10 Aug 2011 14:31:39 UTC
Message: 'kfm' is undefined
Line: 14
Char: 1
Code: 0
URI: en.js
Message: Object expected
Line: 156
Char: 1
Code: 0
URI: index.php?uicolor=%23eee&theme=webassist_v2&CKEditor=ContentValue&CKEditorFuncNum=4&langCode=en
Line: 218
Char: 1
Code: 0
Line: 367
Char: 7
Code: 0
JASON: JUST ADDED THE "FIX" for the kfm/index.php that you suggested to someone earlier..this is the message now:
Timestamp: Wed, 10 Aug 2011 14:44:05 UTC
Line: 155
Char: 1
Code: 0
Line: 217
Char: 1
Code: 0
Line: 366
Char: 7
Code: 0
can you please clarify what fix you tried?
markymark44
Hi Jason: it was this reply you made:
07-20-2011, 01:48 PM
Jason Byrnes
WebAssist Technical Support Manager Join Date: Oct 2006
in the webassist/kfm/index.php page
find the following line:
Code:
<script type="text/javascript" src="j/all.php/can-minify"></script>
and change it to:
Code:
<script type="text/javascript" src="j/all.php"></script>
Had to reinstall new database, reinstall clean website sans PowerCMS files and start over and still had to make this change above which DID fix the problem. One thing you might be interested in...I tried to also install your PHP Mail solution "Contact Form", which rewrote files and caused everything to fail twice before I used another PHP mail solution. I have not had any luck using this contact form yet - are you experiencing other problems with it also? And can it be integrated on the same website that has PowerCMSBuilder installed?
So you have this working ok now?
When installing more than one solution pack, you will need to install them to separate sub directories of your site
install the Power CMS files to:
powerCMS
and the Contact form files to:
contactForm
