Upload problem
Thread begun 8/10/2011 12:53 am by timothy.farrell429144 | Last modified 8/10/2011 5:16 pm by Jason Byrnes | 2700 views | 3 replies |
Upload problem
Tryinng to make a basic upload page. Have followed the getting started guide but no luck. any help is appreciated. the file is below and it's online at:
test1.php
Many thanks.
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "dpx/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "upload", "0", "", "false", $WA_UploadResult1_Params);
<head>
<script src="WA_DigitalFilePro/jquery-blockui-formprocessing.js" type="text/javascript"></script>
</head>
<body>
<form id="form1" name="form1" enctype="multipart/form-data" method="post" action="">
<label>upload file
<input type="file" name="upload" id="upload" />
</label>
</form>
<div id="form2_ProgressWrapper">
<form id="form2" name="form2" method="post" action="">
<label>
<input type="submit" name="submit" id="submit" value="Submit" />
</label>
</form>
</div>
<p>&nbsp;</p>
<div id="form2_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('form2', 'form2_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="form2_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="WA_DigitalFilePro/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
</body>
</html>
you have 2 separate forms, one for the file field and one for the submit button.
the file field and submit button should be in the same form:
<label>upload file
</label>
<label>
</label>
</form>
Thanks Jason. Small files worked but a 9MB file didn;t seem to work. Here is my php.ini.
I added the upload_max_filesize = 20M and changed max_input_time = 60 to 600 but no luck.
Big thanks again
register_globals = off
allow_url_fopen = off
expose_php = Off
max_input_time = 600
variables_order = "EGPCS"
extension_dir = ./
upload_tmp_dir = /tmp
precision = 12
SMTP = relay-hosting.secureserver.net
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=,fieldset="
; Only uncomment zend optimizer lines if your application requires Zend Optimizer support
;[Zend]
;zend_optimizer.optimization_level=15
;zend_extension_manager.optimizer=/usr/local/Zend/lib/Optimizer-3.3.3
;zend_extension_manager.optimizer_ts=/usr/local/Zend/lib/Optimizer_TS-3.3.3
;zend_extension=/usr/local/Zend/lib/Optimizer-3.3.3/ZendExtensionManager.so
;zend_extension_ts=/usr/local/Zend/lib/Optimizer_TS-3.3.3/ZendExtensionManager_TS.so
; -- Be very careful to not to disable a function which might be needed!
; -- Uncomment the following lines to increase the security of your PHP site.
;disable_functions = "highlight_file,ini_alter,ini_restore,openlog,passthru,
; phpinfo, exec, system, dl, fsockopen, set_time_limit,
; popen, proc_open, proc_nice,shell_exec,show_source,symlink"
there are other php directives that effect large file uploads, like post max size.
see the following page for a full list of php directives that effect upload file size:
wap_upload.asp?page=php2
