filemanager don't show icons
Thread begun 8/09/2011 7:09 am by michel336265 | Last modified 4/09/2014 1:59 pm by Jason Byrnes | 6788 views | 13 replies |
michel336265
I have made a update page where my client can edit his page, however when I use the filemanager to select ore upload an image there are no icons and all the images are listed under each other and there is now way to do a browser scroll.
index.php?uicolor=%23eee&theme=webassist_v2&CKEditor=teksten&CKEditorFuncNum=1&langCode=nl
there is a problem loading the theme css file:
css.php
edit that file and add the following code at line 1, this will turn on error reporting and hopefully display a more informative error:
error_reporting
(E_ALL);
michel336265
I have placed the code as mentioned but there is no error code.
If you want I can give you access to the FTP server.
I have this problem now also on an other website where I use the HTML editor.
Awaiting your answer soon,
with regards
Michel
vera155296
Hi. I am having the same problems. No error message displayed when I try adding in the code you suggest. Any help gratefully appreciated
Surdej Web Solutions
I'm having the exact same problem. Any idea what the problem was on this?
Thanks Jason!
see pm
