'Remove item' button
Thread begun 7/12/2009 11:41 am by tequilaboy372007 | Last modified 7/13/2009 9:28 am by Ray Borduin | 1869 views | 1 replies |
tequilaboy372007
I wanted to see if ecart can create a 'remove item' button next to each product in the shopping cart, rather than using check-boxes and an update cart button.
Seems like it shouldn't be a stretch since there is a clear cart button. But how do you limit that button to effect only one item in the cart?
ecart 4.5.0 - PHP
eCart can't create one, but you might be able to.
One way would be add an updatable hidden field for the quantity and then add a input type image button with the same name as the update button. Then add onclick script to change the quantity in the hidden field to zero onclick of the button.
