file size shows a 'minus' figure after updating a record
Thread began 8/08/2011 1:24 pm by lee341019 | Last modified 8/09/2011 11:59 am by lee341019 | 2120 views | 6 replies |
lee341019
I have set up a document sharing site and everything works, apart from when an existing file is updated.
When you update a record (without uploading the file again - just amend some of the other fields), the filesize field shows a 'minus' figure.
If you re-upload the file, then the filesize is fine.
Any ideas?
is it the same minus value each time? or a different value?
send a copy of your page in a zip archive please.
lee341019
same value all the time (always -1).
Attached is the page.
Download_Update.zip
try adding the following code at line 161:
<?php if($WA_DFP_UploadStatus["WA_UploadResult1"]["fileSize"] == "-1"$WA_DFP_UploadStatus["WA_UploadResult1"]["fileSize"] = $row_WADADownload['DownloadFilesize']; ?>
lee341019
Thanks a lot for that. That works.
What does that do. How does it work?
it's an statement that checks to see if the file size is -1:
if($WA_DFP_UploadStatus["WA_UploadResult1"]["fileSize"] == "-1")
if it is, it resets the file size to use the value that is already ion the database:
lee341019
once again, thanks for your help.
Regards,
Lee
